Multi-modes with a 6P or G2?
LiteFan
My L2 is pretty simple and straight forward, push lightly for momentary low, push harder for momentary high. Twist to turn on low, Twist more to turn on high.
@m2usa you could check into the D26 multimode dropins and a clickie tailcap. If you get frustrated let me know if you want to get rid of that 3P.
Justin Case
Do you mean cycling through the modes in a multi-mode P60 drop-in?
If so, easy to do. I have a Kaidomain SKU 2363 4-mode drop-in (high, medium, low, strobe). All you have to do is momentary press, release, and press again to access the next mode. The release can be as long as 2 sec in a 6P and still allow access to the next mode. Interestingly, in a single-cell 3P, you can wait as long as about 10 sec before the drop-in defaults to the high mode instead of cycling to the next mode.
m2usa
San Francisco Bay Area
Thanks guys. Uh... I'm not sure what a D26 is though. Is that a SKU? The 3P is pretty old and lives in my camera bag, so I think I'll be hanging on to it for a while ;) Anyway, I'll look into that KaiDomain multimode.
Justin Case
Before you order the KD 2363, be aware of the following:
- The KD 2363 is not as bright as say a DX 6090
- The one I got was overly long and the bezel had a gap of about 5 mm. I got around that by using a Z32 shock bezel, which was able to accommodate the excess drop-in length.
- In a 3P, you need to drive the KD 2363 with a 3.7V Li-ion rechargeable. A regular CR123A primary results in high, medium, and low all being low.
- The KD web site is correct that the drop-in does not function correctly if you use two RCR123A 3.7V rechargeables (e.g., in a 6P). The drop-in seems to work fine for a couple of seconds, but then starts to flicker. Unfortunately, I didn't have a 17670 to try, but it ought to work.
I am using the KD 2363 in a 3P with Z32 and one AW 3.7V RCR123A cell.
