I've been thinking about a design lately. The main beam would be multiple high output emitters, P7 if you want, with each of them having their own extremely-acute-angle aspheric lens, all behind a window. Surrounding the edge of the inner bezel would be multiple emitters behind only the window and nothing else (no focusing lens), for perfect and bright flood. A123 Nanophosphate would probably be the most ideal power source. Have it so you could select either flood or main beam seperately or together, maybe two closely-mounted forward clickies at the back, different shape and/or texture for the clickies so you could easily tell which button is which. This thing would have pretty ridiculous throw, even with only a 3x3 Cree setup (3 floods, 3 beams). We've seen how far just one behind an aspherical can throw, imagine a bunch with even tighter divergence lenses. The flood would also be great, owing to it's simplicity (Zebralight on steroids). Heatsinking would also be one of the utmost concerns here..
