EvilLithiumMan
After my unintentional water soaking, I disassembled the light to clean it out. (By the way. the six screws on the PCB are extremely small and very easy to overtighten. I stripped two of them.) Not being satisfied with the water torture, I hooked my light up to a bench power supply to see if it could handle 4.2 volts(as in a Li-Ion cell hot from the charger).
It survived, but at the highest brightness level it was drawing 1.6A and getting a little stinky. The epoxy blobbed chip on the PCB was quite warm. Needless to say, all four levels were much brigther. I have measured new alkalines as high as 1.65V, so I know the circuit has to tolerate 3.2-3.3V at least briefly. If I can find a low dropout regulator, I'd like to run it with a Kaidomain 5AH Li-Ion cell, with the voltage set to 3.2 volts.
