NormStu's BOG Q5 prem+ on 2xCR123 primaries is a teeny bit brighter than my DX R2 dropin running on 2xRCR123 Li-ons. Beam profile was identical... both a bit ringy. Andrew's Malkoff M60 was the brightest, not sure what cells he was using, but I have to admit all 3 were VERY CLOSE in terms of brightness, however the Malkoff's beam was very smooth with no rings. For what I paid, I'm more than happy with my DX R2 even though it was barely, just barely, not as bright as the Malkoff & BOG. The differences in output was so small that some people could not see the differences in brightness...
It all comes down to how much you wanna spend. Personally, I don't think you'd be any worse off if you bought the DX R2...
A newb question..with the Malkoff drop-ins, do you have to take off the outer plastic lens, or is it meant to stay on?? It kinda looks like it doesn't belong there...
230 lumens? Can I not convince you to stay with the incandescent crowd and get this little monster...:devil:? (Click the devil)
I do not know if it produces 380 lumens with 2x AW123a cells as it does with three primaries. I reckon it will though because the Li-ion cells should not sag as much under load. That would be one awesome 6P then.
