Okay, so I've been using a Solarforce R2 for a while now and want a brighter drop-in.
ampdude
USA
I've been using the Solarforce R2 D26 drop-in in a C3 Centurion with three AW RCR's. It's a nice LED drop-in and is decently throwy, but I'm looking for something brighter. I've been hearing about the P7 for awhile now, are there any drop-in's available for this yet?
I understand it has a larger emitter area for more flood like a Luxeon 5. If the P7 is to the Cree X-lamps what the Luxeon 5 was to the Luxeon III I'm very interested in it. I'm not interested in a Malkoff because I don't think it would be a whole lot brighter than what I already have if at all. I'm looking for a major step up in output.
Any new drop-ins with new emitters to look at for me?
Thanks :grin2:
bspofford
Colorado
The one-mode Q5 and R2 P60 modules at DX and KD and 0-100% "3-mode" (actually 15 modes in 6 groups) at DX are both brighter at 4.2-8.4V. If you run the Solarforce one-mode R2 with 3X16340 (12.8V) it's about as bright and warmer than the others.
ampdude
USA
Yea, mine is the one mode version. It's warmer than the DX? That's a little bit of a surprise, since I thought both of my samples were a little on the cool side as they remind me of many cool white Luxeons I used to have. Like an XO tint as they binned the cool white Luxeons.
ampdude
USA
I think the problem will be finding a buck converter of the appropriate size that can supply 2.8A.
Tim.
Thanks for the reply, I did not know it used that much power. There appears to be some smaller P7 lights. Do you know what the forward voltage is of the P7?
Timson
Leeds - England
The Vf of the P7 varies as with other emitters and are binned accordingly.
Have a look at Photonfanatic's P7's - They appear to be a very efficient bin as far as Vf goes.
Many people are Direct driving P7's from 3 x NiMh cells or 1 x Li-Ion cell (3.6 - 4.2v)
The P7 is pretty much - just 4 x P4 dies driven in parallel - each die seeing about 700mA @ spec.
Tim.
ampdude
USA
Thanks Timson. It looks doable. I would imagine any drop-in with a buck would have a voltage range of 6V-12V and higher for batteries sake. Runtime on two CR123A's would not be much better than with a P61 since it would be drawing about 2 amps off the batteries. Might be a good combo with a couple of AW 18500's.
Drewfus2101
N/A
ampdude
USA
I would imagine at that current draw the voltage of the cell would drop below Vf very quickly if not right away.
Timson
Leeds - England
An 18650 should run quite happily at 2.8A .....Not done any testing - but I recon it should hold around 3.6 - 3.7v under load - putting you in ballpark DD territory.
Tim
ampdude
USA
Oh yes, and 18650 will definitely run at 2.8 amps . I'm just not so sure about runtime or brightness though. I would also like to be able to use different types of batteries.
