Wolfman
After having it for 2 weeks now, I am ready to write a short review.
Comparing it with my M2, the full beam is slightly more diffused, so at a distance M2 appears a bit brighter (P60). Up close the A2 appears to be whiter (could be the batteries in the M2 though). The white LEDs are great, just what I needed. They are bright enough to light up a room quite well.
As for the A2 body itself, I like it a lot. The size is just right, not too large, not small enough to lose it. /ubbthreads/images/graemlins/smile.gif
One thing I don't like on the body is the hex shaped part of the bezel. In my opinion they are too narrow in diameter, hardly touching a flat surface, which allows the light to roll. Defeats the purpose, they should be a bit bigger. But its no problem really, just something I noticed.
I recommend the light, if this is what you need.
