Surefire 9P Question
zlf15
Will the P60L run longer when used in the 9P versus the 6P or does it have the same runtime just with longer tactical level light. I know the new G3 LED has the same burn time as the G2 LED it just provides tactical level light for more of the overall burn time.
I believe the P60L will have the same brightness in both the 6P, and 9P, but will have a longer runtime in the 9P. If I am wrong someone correct me.
thermal guy
ny
It should just run longer.Thats why i put a malkoff in my 9p instead of a 6p.Great combo by the way!
RichM
Upstate NY
While I can't vouch for the precise accuracy of the numbers in the one case below, they'll give you an idea what 3 cells vs. 2 cells 'can' mean.
But ONLY if your LED is rated for the higher voltage.
From here:
http://www.pts-flashlights.com/products/product.aspx?pid=1-139-114-125-6437
Runtime (2-CR123A batteries): 90 minutes with regulated output, and 8 hours with unregulated output.
Runtime (3-CR123A batteries): 180 minutes with regulated output, and 14 hours with unregulated output.
