binky
Well, I searched here and on the web but didn't find anything very helpful.
I'm wondering if anyone knows or has a link to a site where I can find out the IR & UV transmission characteristics of various materials used in flashlight lenses & bulbs?
I think that because I can buy a very cheap pair of plastic sunglasses that advertise "Blocks UV-A & UV-B" (not that I know what A & B are on the spectrum) that most plastic must have good blocking in itself.
I'm just curious about why, for example, we can have a UV version of the ARC flashlight if its LED is made with a dome of clear stuff (epoxy)?
And some of those HID lights advertise putting out UV. Does that mean that they must have something other than a plastic lens?
What about quartz, used for some bulbs? Does that absorb in the UV or IR?
What about glass? That can't transmit IR or else the inside of my car wouldn't heat up so much from the sunlight would it? But if it doesn't transmit IR, then why does the light beam from my fancy flashlights feel so hot?
[edit] Oh wait, glass must transmit IR because heat lamps probably have housings of regular glass. Hmmmm. Now I'm realizing I just have no clue how that greenhouse effect works. (If only I had a memory)
Questions like that are what I'm wondering...
