Keep your tires inflated to the maximum pressure they'll support, it'll make a harsher ride, but you'll have less rolling resistance
Bad idea. Along with less rolling resistance you also get less grip.
keep your RPM low, the faster the engine is turning the more gas is burned
Not always a good idea. Keeping your RPM too low will cause the car to be unresponsive should an emergency situation arise. To gain speed you need to either floor it and wait until the engine gets to speed, or change gear, both of which take precious time you might not have when that 18-wheeler has just run a red light and is about to smash into you with all its gazillion-ton weight.
I'm just saying.
You should try keeping your RPM low, but don't let them get so low that the engine will shudder and generally be slow and unhappy if you floor it.
(this assumes the car is a stick shift; don't know if this applies to auto transmissions too)
remove bike racks/cargo racks, and anything attached to the outside of the car that would disrupt airflow and compromise aerodynamics
Some people take this to extremes and add all sorts of fiberglass surfaces to their cars in order to make them more aerodynamic. This does wonders for fuel economy, but tends to make the vehicles long and hard to park.
shift into neutral and coast whenever possible
With electronic injection this is not necessarily true. Smart ECUs cut off fuel flow to the engine completely when the car is in gear and moving but you're not pushing on the gas pedal. There is some engine braking, of course, so this is a good technique when going downhill or when you know you eventually have to stop (maybe you can see a red light in the distance - or rather, a green light that you know will be red by the time you get there).
Not all cars do this; some always keep some fuel flowing, others only cut out above a certain speed.
In my Mazda 3 turbodiesel you can actually feel a very slight lurch forward when you're slowing down in first gear and the ECU eventually decides the engine is going too slow and resumes feeding it diesel (at about 3 to 4 km/h IIRC). Before this happens, the instant fuel consumption meter reads zero.
With the cars that do cut fuel flow whenever not absolutely necessary it's perfectly possible to make it down from the top of a hill with the engine ingesting nothing but air.
This is all completely moot if you have a carburated car, of course, as a carb will always let a minimum amount of fuel through the engine.
Also moot in the case of two stroke engines (mostly motorbikes, scooters and mopeds), which have total loss lubrication and so require some fuel/oil mixture going through them at all times.
