Re: Novatac 120P question
If you have a 120P, the runtimes are like this:
120 lumens 30 minutes on high
85 lumens 90 minutes on high
Your eye can barely tell the difference between 120 and 85 lumens. I set mine to 85, and when they say 85, it IS 85 out the front of the light.
I can tell you, the manuel that came with the light was pretty far off, conservatively, on the runtimes. The only one that was spot on was the 30 minutes on 120.
The other settings are close to double what the pamphlet stated.
The 85P, 85T, and 85E are also close to 90 minutes.
As I recall, on the 60 lumen setting, the runtime was about 5 hours before the light would step down.
The only time there is any kind of need to use 120, is when you want a bit more throw. It doesn't seem to make a difference under 100 yards, once you reach that distance, having it at 120 does make a difference, but just slightly.
