If you browse
the welcome mat you will find answers to some of your questions:
Q: What's the difference between "lumens" and "lux"?
A: Lumens measure the total amount of light output from a particular source. Lux measures the intensity of the light hitting a specified area. For example, an ordinary household lightbulb generates about 1000 lumens, but the intensity of its light at a particular point, such as on a book you're reading, will be comfortably low. Almost all flashlights rely on an optical device such as a reflector or lens to squeeze most of their output into a small area, which allows you to illuminate a point of interest with enough intensity, but without requiring a lot of power. To illustrate this concept, try the following: First, look at your room's ceiling light. In all likelihood, you can stare at it without much discomfort. Now, try looking into a weak flashlight like a traditional incandescent Mini-Maglite. You'll notice that it seems very bright. This is lux. Now, remove your Minimag's head to put it into candle mode. Try switching between its output and your ceiling light's output. Since they're now illuminating approximately the same area, the much higher lumen value of the ceiling light will provide much higher lux values at a chosen point. An extreme example of high lux and low lumens is a laser, which doesn't really create that much light, but focuses it into a tiny, brilliant point.
