Can you put a P7 in a HDS or a NovaTac??
datiLED
Atlanta, GA
Will this work with just a plain emitter swap or you need completely redesigned drivers to drive the P7?
The main problem would be the physical size of the emitter. The P7 is huge compared to a Luxeon, or Seoul P4 LED. The other issue is trying to get a reflector to fit that won't give you a terrible donut.
The LED will be underdriven with the stock driver, but that is not a problem. It would cut down on the heat.
My advice would be to wait for the Seoul V-bin P4.
But, if anyone could do it, it would be milkyspit.
gottawearshades
Howdy.
I was also considering this. It would basically make a NovaTac into a Mule.
There's a discussion of this going on now in the Milky L1 thread
One mod I would suggest: Milky just installed a K2 TFFC in a 120P for me. The beam is beautiful, creamy and a bit brighter. I love it. :thumbsup:
Tessaiga
A Little Red Dot 1 degree North of the Equator
Howdy.
:twothumbs the good thing is that I have exactly one of these on its way to me... will see how it goes..:D
Thanks for chiming in DatiLED.. that has always been your advice... I really must get either a HDS or a NovaTac to you once those emitters are out...:D
