Hey,
I'm in the midst of planning a series of mountain climbing trips for the summer. As many of you probably know, this involves a thorough list of supplies and equipment. Eventually this list turns to the issue of light.
Everything I take has to be carried, so the goal is to keep the amount of gear, therefore my pack, as small, simple, and light as possible. For years, I carried a Military 2D Anglehead, and a MiniMag 2AA, with an appropriate number of spare batteries/bulbs. Over the past year, my lighting options have significantly increased, so I'm finding the question more difficult to answer.
Late last fall I climbed Mt. Adams, with several hours of the ascent and the entire descent at night. Based on this experience I have decided to break down my options as follows.
Primary/Lowbeam
-Inova X5, Arc LS, or MiniMag w/ Opalec as a low output, extended burn trail/task light.
Auxillary/Highbeam
-Brinkmann LX, SF, PT 40, or PT Surge as a long throw, high intensity beam.
Headlamp
-PT Aurora as a low intensity, extended burn headlamp
Backup/Reserve
-Arc AAA LE, Inova, EliteMax as a backup.
There may be other lights that fit these categories, but here is my reasoning for these lights. A primary low intensity, long burning flashlight provides ample light for walking, seeing within close proximity, without completely sacrificing night vision. This is an opinion, but I find that I'm more aware of my surroundings and have an easier time hiking with my eyes fully adjusted and only enough light to be sure of where I'm placing my feet.
The PT Aurora fits the same niche, but has the headlamp advantage, providing light when both hands are necessary for mobility, which (if you're lucky) leaves the primary light swinging from the D ring of your pack straps. It serves to double the available light when used with the Primary, and is compact, light, and durable.
The PT Surge is the long throw auxillary, when you need to spot something out of range, or visibility is low (snowstorm, trying to find a rock cairn in a rocky snowfield, etc /ubbthreads/images/graemlins/smile.gif ). It is only used for moments, minutes at best.
Finally a backup, something that can put out enough light, and last long enough to travel by should Mr. Murphy strike and deprive you of your primary light(s). It also helps for those moments when you have to change your batteries, or find your missing light.
Personally, I prefer my lights to be fairly robust and waterproof, or at least, water resistant. I also try to limit the selections to one or two types of batteries. This allows the battery reserve to be more versatile, and therefore, smaller.
Of the lights I currently own, I will be taking the Opalec as primary(Lowbeam), PT Aurora as my headlamp, PT Surge as my Aux(Highbeam), and EliteMax as my backup. All the lights have decent burn time, and are very water/shock resistant. The same reserve of AAs can feed all the lights save the Aurora, wich would only need a modest supply of AAAs.
I have considered switching over to a 123A selection of lights, as I believe they are potentially lighter (though more expensive to run), but the lack of an offordable, robust light as an Aux/Highbeam holds me back. I've considered SFs, such as an E2E/O. I agree these would be excellent, but they are not water proof (shy of the M2) and prone to bulb breakage. At $15-$25, a Tech 40 or Surge wins, especially when a single perfume sample vile can carry the spare bulbs (at $4 vs. 15$) necessary, and have the added benefit of adjustable beams.
I'm sure someone is going to say "hey, the opalec isn't waterproof". Absolutely right, however, it is highly water resistant, has no bulb to break, and is fully regulated. The PT Impact/Impact II/Attitude would make good substitutes, or the more expensive Arc LS, but the OMag works fine.
As far as other lighting needs, when I sail or hike at night, a strobe is a nice thing to have, such as the ACR series. I've always carried my fathers Firefly 4G (123As) or my MS-2000 (AAs). The need for a strobe to be submersible/exceptionally bright on a backpacking trip may be negligable, so I've considered carrying just the EliteMAX to serve both as strobe and backup. It appears to be bright enough on pulse/SOS, any opinions?
Sometimes I take a pair of glowsticks or a krill, but with number of lights already carried, I don't think they're necessary.
Has anyone ever carried road flares? The pop/strike kind, not the gun. I used to hike with a guy who always had two waterproof flares strapped to his pack. The idea was if you really needed to signal anyone, see, or defend yourself really badly (aka furry and ferocious), they could do the job. Over the years I've surprised (or been surprised by) bull moose, bears, wolves/coyotes and such, and so far I've been lucky. The idea of carrying a flare for defense, in addition to the basic utility of the flares, seems sound. Obviously if you're hiking in an area with alot of dried brush, any kind of flame seems like a bad idea. What do you guys think?
I hoping to hear from fellow backpackers on this, but I think the questions above are applicable to everyone. Considering eveything you take has to be carried by you or on your back (food, water, clothing, gear, etc), which flashlights would you bring? Which batteries? How many? I want to know what you think.
Writing this has reminded me that I have a package scale... I'm really not a weight nazi, but I think I'll end up weighing my lights & batteries out of curiousity. /ubbthreads/images/graemlins/smile.gif
Take care everyone!
(P.S.- My dad gave me that 2D light back when I first joined the Boy Scouts... kinda sad I have to retire it.
/ubbthreads/images/graemlins/frown.gif )
Primary/Lowbeam
Auxillary/Highbeam
Headlamp
Backup/Reserve
Take care everyone!
