Got my new Wolf-Eyes Angel-C : Q5
LightScene
It's a neutral gray with mostly a smooth finish. It has a reverse clicky with a very simple UI. Turns on in high and switches to medium and then low by pressing the switch. It has a fairly broad well defined hot spot. If you are 5 or 6 feet from a wall, there are no obvious rings. It's a very nice beam. Better than my other Crees. It tail stands, but with a wobble. The clip prevents it from rolling more than 1 turn. It takes the older blue RCR123's without any problem. The diameter is 20mm, just thin enough to be a comfortable pocket carry for me. I'm quite happy with it and recommend it. You can get a CPF discount by contacting Mike at pts-flashlights.com
