- Hard anodized 2.25D M*g designed for 8x14670 lithium-ion batteries for 14.8 volt operation. (2 parallel/4 series) Shorter than 3D M*g but brighter than M*g85.
- Body is M*g 3D shortened to 2.25D and bored out in 4 slots to accept 4 li-ion 14670 across in 2 stack. 2 parallel/4 series (14.8 volt, 2.2Ah)
- Outside body is cross machined for great look and sure grip. Head is also reshaped to conical form for unique look and very fine finned for better heat dissipation. Completly deanodized, polished and reanodized in gun metal gray type III, natural type III color.
- Battery holder designed to accept 4x2 li-ion 14670 batteries which are slightly gapped to avoid shortage in case battery cover is torn. It has shorter extended charging jack to recharge batteries without removing tail cap. You can also recharge the pack out of flashlight or simply remove batteries to recharge individualy. This battery holder has very low resistance and capable of high drain bulbs up to 3.8A with single click. Center pin of charging jack is positive and I will include a male charging jack too.
- Lithium-ion batteries have very low self discharge and don't need to top off very often.
- Comes with (1x) custom-made CL 43-watt (14.8 volt, 2.9A, 10 Hrs life) which produces over 1450 bulb lumens. (Made exclusively for Fivemega)
https://www.candlepowerforums.com/threads/147729
HA 2.25D M*g with battery holder $135
Dual function aluminum reflector $30
High temp G4 bi-pin socket/adapter $19
Bi-pin 14.8V bulb $10
AW 14670 @10.99/ea. ~$88
selling altogether for $200... $160usd shipped conUS ***SOLD
paypal to: abz117 [at] yahoo (d0t) com
within (2) hours from the time you state an unconditional, "i'll take it!"
also listed at http://www.cpfmarketplace.com/mp/showthread.php?t=179509
