Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
My experience with modern high capacity AAs sporting as much mAh (2700mAh) as a lower capacity sub-C cell is that they're not as resilient as older NiMH and NiCds
My oldest NiMH are Energizer 1200mAh.. I think they're circa 2000 and even though they've been mostly abandoned, leaked a little and discharged to 0.00v, after a few cycles, they're still giving 1,000 to 1,100 mAh even at 1A load.
Same with industrial NiCds I have that must be over 10 years old, but still have low internal resistance and 2.3Ah capacity
In comparison the high volumetric density NiMH cells lose capacity after not that many cycles even if they're taken care of well... and it seems like a few mishaps (discharging to polarity reversal)
So, just how damaging is accidentally leaving a light on and causing a cell to go into polarity reversal?
Would you say it's like accidentally rubbing against some brush along the side of road adding to wear and tear type scratches or is it more along the line of backing into a pole?
