IsaacHayes
Will a Luxeon fry my Car\'s Dome light circuitry??
I want to modify a spare domelight cover for my car that will plug into the original bulb holder and contain 2 luxeons. A Royal Blue and a normal White. It will have a switch on the outside of the cover for White/Blue/ & Off since my car will always turn it on when you open the doors no matter what.
The thing is, my dome light is run by a circuitry controled box, that dims light until it goes out much like a theatre when you close the door. (it doesn't go out instantly with the door switch). I know incandecents eat a lot of juice but I don't know what Watt the dome light is... Will it handle a 1W luxeon with a resistor?
I will be using a resistor instead of a voltage regulator becuase I want to keep the dimming effect and a regulator would keep it bright for too long. The resistor will probably keep it glowing/dimming for a longer time too as I belive it uses a capacitor to slowly dim out the lights...
So do I have to worry or is the interior lights of a car a lot more draw than a 1W luxeon? /ubbthreads/images/graemlins/confused.gif Also should I go with a HD or a LD? (no optics)
