Hello.
I have a Fenix P2D Q5 and a Romisen RC-N3 Q5.
With the Fenix on high (not turbo) they both seem to put out a reasonably similar amount of light. The only difference is that after a few minutes the Fenix is quite a bit warmer than the Romisen.
Is this...
A. bad, the Fenix is generating more heat than it should.
B. Good, they generate more or less the same heat but the Fenix dissipates it better.
Note: Neither is hot, it's just that the Fenix is definately warmer than the Romisen. Based on them just sitting on a table untouched for a few minutes.
Any knowledge on this would be greatly appreciated.
Thank you.
Is this...
Thank you.
