Theatre project needs super bright source, hard shadow.
faulknerfilm
Hi all,
This is for a theatre project I am developing as a designer, can anyone help me?
I want a superbright, (cool, so LED is perfect) single point source (for hard shadow) light source. Doesn't have to be battery operated, but should be equal in lumens to a 100 watt bulb or better.
Anything? I have heard that the SSC P7 Bin C 900 Lumen LED is pretty amazing. But is it possible to get any brighter?
The Shadow Man
WadeF
Perkasie, PA
Not sure if you're going to be able to do this with a LED. How far away is the light source going to be from where it is projecting?
I know I have seen incan based setups that use a lens to focus the light for this type of job, and you can insert cut outs into it to project a perfect shadow of whatever shape you insert.
Crenshaw
Singapore
if its what i am thinking, you need a proper spotlight thats used for stages. :)
Crenshaw
enLIGHTenment
Ottawa, Canada
A 100W bulb incandescent puts out between 1500 and 1700lm. There's no point source LED on the market that can match this. The best that can be done with an LED would be an array of two P7s behind optics, but this would give you a double-edged shadow unless the light source is well away from whatever is casting the shadow. LEDs aren't going to work if you're looking at casting shadows through a gobo mask.
Your best options are probably to use an incandescent and put up with the low color temperature or go HID and put up with the high cost.
gadget_lover
Near Silicon Valley (too near)
I think that when you are looking at a single point light source, the 100 watt incan VS P7 becomes an interesting comparison.
The 100 watt bulb may emit over 1,000 lumens but it does so in a spherical pattern. The P7 may put out 1/2 the light, but it all goes forward.
My 3 watt 150 lumen LED pocket light overpowers the light from the 150 watt, 1,000 lumen floor lamp next to me. An easy way to see the effect is to find something where the floorlamp is casting a shadow, and shine your 150 lumen on the shadow. In my case the shadow disappears.
Of course, you can also just use a light meter, but shining your light on things is more fun.
With small lights like the Fenix P2D available for under $75, it's easy to build a test bed to see if a humble Rebel 100 or Cree Q5 will do what you want with only 150 lumens or so.
You do have some small, bright lights, Right?
Daniel
Jarl
Southern UK
This has probably already been said, but 100W halogen=1500 lumens. No chance with current emitters- you're better off staying with incans for this project due to heatsinking problems, driver problems, optic problems, etc.
LukeA
near Pittsburgh
Did you read above? A P7/MC-E emits light in a pattern such that it can equal the output of a 100W incandescent in one direction (i.e. no reflector for the incn bulb.), depending on the application.
enLIGHTenment
Ottawa, Canada
betalight
Perhaps something like this with an aspheric lens....
http://www.dealextreme.com/details.dx/sku.5848
- Input voltage: 18V~20V
- Total power consumption: 20W
- Output: 800 Lumens Total (manufacturer rated)
Gunner12
Bay Area, CA
What size and how far away?
A(or a few) current gen LEDs coupled with a custom or pre-made elliptical reflector might work. I don't know where the lens should be(at the other focal point?) but that should collect most of the light and produce a well throwing beam.
:welcome:
LukeA
near Pittsburgh
:welcome:
The FP of the lens should be the second FP of the reflector. There should also be some sort fo shielding to keep spill light from hitting the lens.
I don't know of any preexisting solutions for this though.
Gunner12
Bay Area, CA
Thanks Luke A, I've been wondering that since I realized that elliptical reflectors can be used well with a lens.
A custom reflector might be needed.
Crenshaw
Singapore
If this is the kind of effect your are looking for, i dont think LEDS can help you much yet.
better off looking for a true spotlight.
Crenshaw
monkeyboy
UK
I think I see what you're looking for. I guess you can't use a reflector or optic since this will diffuse the shadow.
The osram ostar is probably the best LED for the job. If you can find a good bin that is otherwise you're better off with the SSC P7. There are brighter LEDs but they use large arrays of dice and won't give you the point source you are after.
You may be able to get the P7 near to the brightness you require by overdriving. Mount it to a HUGE heatsink and you should be able to drive it up to 4A. You could even try a CPU heatsink and fan. It won't last too long though. Some of the modders here have driven the P7 to 6A for a few seconds.
A better option would be to build something out of an automotive hid ballast and bulb. This would be much brighter but be careful, there are dangerous voltages involved.
BTW: this would be better in the "fixed lighting" forum.
