Is this truely Solar Powered? (dx keychain light)
Crenshaw
Singapore
I recently bought this
http://www.dealextreme.com/details.dx/sku.13088
And would really appreciate if someone with more technical knowledge then me could hazard a guess if theres a chance this thing can be operated by solar power.
Yes i KNOW there are coin cell batteries there, but is there a chance this batteries can be recharged by the solar panel?
there was some speculation that because the Current produced by the solar panel was small enough as to be able to "recharge" primary cells.Or possibly the coin cells are of a rechargable kind?
Here you see it with a DX fauxton. Its very bright, even if it wasnt solar powered, its still not that bad.
And the GUts
Crenshaw
paulr
Yes there's a similar light called the Freelight or Swisslight (made in Switzerland) that's been reviewed here a while back. This DX thing is a much less expensive semi-knockoff with fewer features. The solar cell looks about 20x40mm which should produce enough power to recharge the battery in a day or so of sunlight if you clip the light to your backpack or maybe a zipper pull. Might make some sense for a very long hiking trip, except that model appears momentary-only and not well-enough built to really rely on. Even the Swiss one was a bit dubious. The concept is nice though.
You might also look into the Photon Rex which recharges from an external dc source, such as an AA cell that you could charge with a solar charger.
Crenshaw
Singapore
The coin cell is marked as "LIR2032", this is a li-ion rechargeable - so yes, it can be recharged. There are spec sheets on google if you search.
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2420
http://www.powerstream.com/p/Lir2032.pdf
thats great! thanks Daniel
thanks for the input guys, i dont really need a small rechargable light, it jsut that this seemed like interesting thing to have, a solar charger+battery+light unit all in one, for a very small price. Imgaine, small giveaway baggies at "green day" roadshows or whatever would have these inside.
Crenshaw
raiste
Why the diode?
I think it prevents the battery from discharging into the solor cell(s) when there is not enough light present for the solar cell output voltage to overcome the battery voltage.
Jarl
Southern UK
That'd make sense. Thanks!
LED-holic
Terminal 4
crenshaw - which one is the solar powered led and which one is the fauxton in your beam shot photo?
Also any size comparison photo? say to a AAA or AA?
Crenshaw
Singapore
hmmm on the left is the 3x 5mm led solar light...
size comparison, its quite big for a keychain light. Did you by any chance buy the "keychain" universal remote control? its about that size, just thicker...ill take another size photo with my NDI when i get home tonight...:)
in the meantime you can use the blue microfibre cloth's little squares to figure out a scale..:nana:
Crenshaw
Omega Man
East Coast
Thanks for posting about this Crenshaw, I have about 3 of those solar keychain lights on my DX wishlist, and have been wondering about them.
Anyone think keeping one on your dashboard would damage the light rather than keeping it constantly charged?
swxb12
Bay Area, CA
OT: So if I keep charging up the LIR2032 in my crank light, will I have guilt-free lumens in my Photon?
Crenshaw
Singapore
there was quite a bit of speculation on the product board too...i just wanted to know very badly..:D
i have three of these now.
swxb12, probably? its like a smaller version of the rex really..:D
Crenshaw
Fallingwater
Trieste, Italy
You will have a dead crank light.
The vast majority of LIR2032 crank lights (possibly all of them, not sure) have no charging hardware; they just hook the cell to the little motor that makes the power, without anything but a diode bridge inbetween. And inbetween the cell and LED(s) there's just a resistor or three, or possibly some components for multimode operation (it's unlikely they control cell voltage though).
As you may know, LiIon cells are very sensitive to overcharge and overdischarge. Crank too much and/or run the light flat every time and you'll kill its cell quick smart; many people complain of not getting more than one cycle out of their crank lights before the battery dies.
There are two solutions to this problem.
1) get a LiIon crank light with proper charging hardware monitoring the cell, if one even exists;
2) get a NiMH-powered crank light. NiMH cells don't particularly like rough treatment either, but charging too much or running the battery flat every now and again is not death on a stick to them the way it is for LiIon.
Some more info in this thread I opened some time ago.
Crenshaw
Singapore
thats interesting....im hoping that the rate of charge from the solarcell is enough that you wont over charge it?
i realised i promised pictures and totally forgot...oops! ill take some now...
with 3 of the 5 other lights i have on my office table (all of which i take home everyday)
Crenshaw
Fallingwater
Trieste, Italy
Don't really know, my knowledge of solar cells is not sufficient to answer your question.
About the solar light: it's nifty and all, but I'd be wary of putting something with a delicate glass surface in the same pocket with my keys...
