High guys,
there seems to be such a brains trust here on CPF, I hope some can help.
Im looking to make a mountain bike LED light. Id like to keep it as slim as possible with the most lumens possible. Hence I would like to use only a single led. Power will be supplied to the back of the head via cable from remote battery pack.
I was looking at the old KL3 heavily grooved head,because I like the wider beam(compared to the newer KL3), and Im thinking that the grooved head will give better heat dissipation(true?)
Is there an after market drop-in High output LED/reflector ,hopefully 300 lumens or more, that will fit the KL3, or maybe a special mod you feel would work very well even if it takes some tinkering?
If I need more light, I would have a 2nd LED unit built up, run a split power cable and switch it on as required.
Thanks for any good advice or other recommendations you may have.
