Look What I'm Getting...
qarawol
Southern California
'ARC mania' is at it again.
Look what he made for me.
A SINGLE die LED --- A SINGLE CR123 battery --- around 400 lumen output, twisty...
No further details. :D :grin2:
Njoy...
alfreddajero
VA Beach.
Now that is a lot of light.....whats it made up of and how long is that sucker.
WadeF
Perkasie, PA
400 lumens from a single die emitter? Maybe a single dome emitter? Could be a P7.
Crenshaw
Singapore
omg, what is this monster!
single die? thats highly unlikley....
even an r5 would need to be driven insanely hard for that level of light. maybe its the Cree Mce?
Crenshaw
yaesumofo
Eastern Pacific, LAX DM03 sw actual
400 lumen's for
What 5 minutes?
Really?
While I suppose this is cool if you like to have a little show off light but...
Just do you expect to be able to do with it?
How long do you expect the batteries to last?
What kind of emitter?
IMHO a light like this carries little or no utility value.
First of all it is too bright to be practical for anything except for showing to your buddy and saying hey look at this and then saying WOW!. Then It is unlikely to operate at this brightness level for any sort of useful length of time.
Personally I just don't see it.
Especially since it is likely to be priced somewhere north of $200.00
Personally If I buy a light which is somewhat expensive it has to be of practical use. In the [past I have spent too much dough on lights which have sat and done nothing for long periods of time.
NO More of that for me. If a light can't prove it's utility shortly after I buy it it is gone.
I no longer even buy lights which do not fit my idea of practical tool grade flashlight.
The only practical use I could have for light of this nature is on my keychain. always there ready to produce a blinding bright light until the battery dies.
Sorry If I am less than enthuistic. That said I am open to learning more about this light.
Yaesumofo
yaesumofo
Why not post all of the specs?
T7075 aluminum
HA natural
Chem kote interior
AR coated mineral glass lens
Cut down 27mm orange peel reflector
Converter- Will have 5 output choices - SC1500, SC1100, SC900, SC500, Buck/boost SC400 or Multi-function boost only at 475ma in high mode.
Run time- Depends on converter used SC1500 - 25 minutes.
LED - TFFC 220 lumen K2
Approximately, over 300 lumen light output with SC1500 DC/DC converter.
1 x CR123 only.
Key ring hole on battery barrel
Serial number
Only 35 units total will be made
BTW they are sold out.
The specs say 300 lumens not 400.
Yaesumofo
yaesumofo
It looks like the P7b option will produce 400 lumens!! wow. I still do not understand the OP lack of information......
These are not my favorite types of postings.....partial or incomplete and inaccurate information. I am sure it was not deliberate.
Yaesumofo
qarawol
Southern California
T7075 aluminum
HA natural
Chem kote interior
1 x CR123 only.
Serial number
Yaesumofo
Possibly a SPECIAL custom job...??
HA natural --- yet the picture shows it to be bare
K2 LED --- er... um... a... nope!
Key ring hole on battery barrel --- no hole there
Serial number --- yet no number listed - Prototype -
The specs say 300 lumens not 400 --- hmmm? if all of the above info is different, then... I'll stop here.
Yaesumofo
The original post (OP) is what it is. Re-read it... especially the second line.
Njoy...
WadeF
Perkasie, PA
So is the SC1500 sending 1.5A to the K2? 300 emitter lumens makes sense then. So would a Cree R2 at 1.5A be over 300 emitter lumens? I assume the advantage of the K2 is tint, and it can better handle the higher current and temps?
