Not FS: 92mW Blu-Ray! - Kryton Barrel/FlexDrive/803T!
No longer selling these... Please read this:
http://www.laserpointerforums.com/forums/YaBB.pl?num=1231511226/0
Nothing but the best components for this awesome blu-ray!
The one pictured here has been sold, but I have one more of these 'hard to come by', 1st run barrels to build!
* PHR-803T blu-ray diode.
* Kryton barrel by Kenom.
* FlexDriver by Lava. (set at 90mA's)
* Powered by 2 X 3.0 volt Lithium primaries.
* You can expect between 80mW's to 90mW's at this current. (AixiZ acrylic lens - plastic cut away) Some are running these diodes HOTTER.
The excellent driver by Lava, is held in a sturdy position by some 'quick set epoxy putty'. Which will come off easy enough if the LD should ever need to be replaced.
Here's a beam shot:
Normal garage lighting, with some smoke.
I have left the aperture cap and o-rings off, and will include them for the buyer to install if desired. I personally like the aperture cap installed. But it makes focussing a little more tricky...you have to use a toothpick or a small screw driver with the aperture cap installed.
My personal preference for the o-rings, is not to have them installed. (I like to tighten the end caps metal to metal, and tighter than the rubber o-rings allow - just to make sure of a good connection, as the negative battery current travels through the threads)
Using lithium primaries, mean that the laser can sit for months, and not lose charge.
Match burn video:
http://www.youtube.com/watch?v=29rmzOsaMI8
Red burner builds, testimonials, and reviews are here!:
http://www.sonic.net/~jayrob/MXDL/
Jay
Here's a beam shot:
Match burn video:
Jay
