Hi, I'm a newb. I tried Stefan's p7 mod for my 3d maglite.
I took my 3d maglite, installed H22a's heatsink with arctica alumina epoxy to a CSXOI P7 LED. Then I wired up Stefan's amc 7135 1 amp multimode driver and the 1.4 amp slave board. So that should be 2.4 amps.
It turns on, and I have all the modes, but when I tested the mA at the tail cap...I am only drawing 1 mA. Not 2.4 mA; only 1 mA.
It's running on new alkaline D cells. Is that the problem? or did I screw up the wiring? Does anyone know what the mA should be with alks using stefan's mod?
I'm planning on buying nimh but I want to make sure there is no problem other then the alkaline batteries. If I get nimh D cells will the mA increase upto 2.4 amps from the 1 amp with alks?
