Malkoff
Results 1 to 19 of 19
Thread: question(help) about Fenix L2D Q5
    Jun 2008
    Southern California
    Default question(help) about Fenix L2D Q5
    Hi this is myfirst post here.I just purchased and received a Fenix L2D Q5 and it is great sofar but on strobe and 3/4 of the time on turbo the light hisses.It hisses every time it flashes on strobe and constantly on turbo.Is this normal? If not I can get it replaced by LAPOLICEGEAR.com.
    Thanks everybody.
    Default Re: question about Fenix LCD Q5
    Not sure what an LCD is (L2D, L1D?) but hissing has been common on the L/P series with reverse polarity protection circuits. Look at the (+)contact on your head for 2 metal contacts on either side of the main (+)contact.
    Jun 2008
    Southern California
    sorry I meant L2d Q5
    Sep 2007
    Philippines
    Default Re: question about Fenix L2D Q5
    I also have a L2D Q5 that I bought from Fenix Store two months ago. I just tested it if it emits hissing sound on turbo and strobe. No sound on all modes. That's all I can share.
    Flashaholic* TONY M's Avatar
    Jan 2008
    Belfast, NI
    There have been a few cases of the hissing L2D when in turbo and strobe. It is annoying that this happens but I don't know if it is worth worring about though...
    Default Re: question(help) about Fenix L2D Q5
    I think I would find the noise annoying. I wonder what could be causing it?
    Jan 2008
    Belfast, NI
    Here is another recent thread on this issue with more info.
    http://www.candlepowerforums.com/vb/...d.php?t=200866
    I don't know exactly what that is or if it is harmful, but my L2D Q5 does not hiss and the light is not supposed to. So, if you want to find out exactly what is going on, continue, but I say you already have grounds to request a replacement.
    I have heard ticking out of some of my lights/modules, that is the pulsing charge across a capacitor. I have heard batteries hiss. What batteries are you using, how new are they? If you can go to a fresh set of good rechargeables and it changes that will be good to know.
    Jun 2008
    Southern California
    Hey thanks for the response guys MrGman ive een using Duracell copper top and energizer it didnt hiss with the energizer but it would not go into turbo it would be the same output as the high mode.I'm going to have it replaced by LaPoliceGear
    Oct 2002
    Baden.at
    Default
    Sometimes I have a hissing sound with my chargers - when the contact wires are not tight to the battery contacts.
    Possibly the spring tension of the L2 is to weak with batteries that are a bit shorter than usual?
    Try putting a magnet, or some metal disc, between 2nd batt and end cap. That would give more pressure on the spring and thus the batts. Results might be of importance. If the sound stops, it is not in the dirver.
    Jan 2008
    Belfast, NI
    Quote Originally Posted by James Hamon View Post
    James H, you will get much better performance by using NIMH cells in an L2D as it is not designed to use alkalines.
    My L2D makes noises regardless of the battery type or brand so that rules that out as the cause.
    Jan 2007
    Southern UK
    Mine does the same. It's not loud enough to be noticeable during use, so it doesn't bother me.
    The alkalines cannot deliver the current that rechargeables do, even brand new name brand batteries are often not that good. The Q5 model in turbo draws quite a bit of current. So there may be nothing wrong with it other then your battery choice. I would get some good 2000mAH rated batteries to try before I send it back.
    I am told that AA batteries that claim 2400 to 2600 mAH don't make that claim and are actually no good.
    I am using the Rayovac "Hybrid" NiMH rechargeables right now and they appear to work very well. Got them and the charger at a Fry's Electronics for only $20.00 (6 AA's and 2 AAA for that price).
    Jun 2008
    Southern California
    I have tried a few different batteries as suggested Nimh,alkaline but it still hisses but i was wondering does that mean it should be returned.Oh with the nimh the light is alot more powerful than with alkaline batteries thanks for the suggestions guys.
    The Wood is cut,
    The Bacon is cooked,
    Now itís time to sleep
    RIP our friend.
    Jun 2008
    New England woods.
    Quote Originally Posted by MrGman View Post
    The first set of batteries I used for my L2D Q5 was mis matched alkalines I had at around the house. No sounds from my flashlight on any mode. Even with these I was impressed with the light. Maybe the alkalines don't last as long but they seemed ok to me. However I do have rechargables and they are now being used. I agree they work better. Just saying the alkalines will do the job if needed.
    Jun 2008
    Southern California
    Buttrock Re: question(help) about Fenix L2D Q5
    I agree the alkaline will do the job but the nimh(rayovac hybrid) are awesome so far.
    The Wood is cut,
    RIP our friend.
    Jun 2008
    New England woods.
    Yup.
    Also I don't know if my Fenix L2D Q5 premium has reverse polarity protection circuits. I got the light a few weeks ago from Brightguys. The instuctions warn about reverse polarity but that could be just a standard warning. Some people say the ones with reverse polarity protection circuits make sounds and those older ones without don't but somehow I question this as others claim they make a little sound and some like myself hear nothing or don't know if the light is older or newer. I just tested it again on turbo and strobe. Put the light right against my ear and heard nothing. Heard nothing in the woods on a trip to the AT last week and any little sound is heard at night in camp. I just almost got a stroke from the blinding strobe mode.
    Jun 2008
    Southern California
    Yeah I agree it is a kick a$$ flashlight for the money and Mine is the newer model with the reverse polarity that is the common idea is that it was the batteries or the reverse polarity that caused the hissing. thanks for your help.
