tvodrd
*Flashaholic* ,
My Director of 14 years at work announced he is retiring. I suggested to my machinist that we could make him a unique retirement gift- a custom, hi-tech flashlight /ubbthreads/images/graemlins/grin.gif in our usual gold and black ano we use for the production equipment we build. Well, word got out and others wanted one too /ubbthreads/images/graemlins/grin.gif . I sketched-up an about as small as practical 123 LS design, and ordered some 3/4" 7075T6 and alloy 145 copper bar. ($Ouch!$) For the driver electronics, I chose the LEDynamics MicroPuck, primarily, because I had several and the long run time they offer on a 123. (Wayne/dat2zip's boards are a much better formfactor, and would reduce the O.A.L. by about .1" but I had several pucks /ubbthreads/images/graemlins/grin.gif )
We made the pieces in our "spare" time. The LSs get epoxied to the copper midsection:
For a + battery contact, I made brass pieces which press over the pucks:
The assemblies are a tight fit, and get potted when done. For the neg battery connection, I cut a .010" W. slot with a slitting saw and staked the puck's lead into it. Soldering the leads to the LS was accompanied by a few cussy-darns:
We made a punch to make the lens gaskets from .030" clear silicone rubber sheet, and it is almost invisible. Threads are 11/16-24. DL123s drop in, but SF123s some little pinky assistance, and 2-3 taps dislodge them. The neg bat contact is a #2-56 round head, slotted (bifurcated /ubbthreads/images/graemlins/grin.gif) mach. screw, located .025" off axis to provide some "wipe" during make:
Some lessons learned. HA is a PITA! The anodize run included both 7075 and 6061 parts. The 7075 guys came out kind of a light gray and the 61 parts had the greenish "OD" cast I prefer. Wierd thing is last night I did an hour and a half run on one to see how hot it was going to get, while holding it and shining it around (heat's no problem- warm not hot) and this morning, that light's ano has turned green! I guess from a combo of heat and skin oils?? I like it! Edit: (Thanks Roth) the optics are NX-05s, turned down to .650" dia, and shortened from the front to .375". Actual front aperature is .575" dia.
Another edit: The crummy pic above doesn't show the glass lens and its gasket very well. The gasket ring drops into the bezel, followed by the lens and then the optic. The bezel O-ring is major squeeze, so no "Loctite" is required.
Larry
Larry
