zband
I really like these lights but each has its pros and cons...
I want to use rechargeable batteries - can I use a pair of rechargeable 123 batteries in the P3D? If so, 900 mAh x2 = 1800 mAh is kinda weak, so I thought if the TK11 can use either cr123 or one 18650 why couldn't the P3D also fit one 18650 ? It seems its the same voltage but with just a higher capacity... Thats my battery issue..
TK11 has an advantage of using a 18650 and an easier UI mode, but the low setting is kinda "high" at 60 lumen... Damn I wish I could choose both and be done with it...
