multistage 6P
Chrontius
Orlando, FL
McC2S switch
So, I'm thinking of getting one to go with my Malkoff, but I'd actually like it to drop input voltage below the 3.7 volt floor for regulation to kick off so it's actually... you know, low.
Question 1: What resistor value should I get, and what sort of output should I expect?
Question 2: This requires a lockout tailcap to house it in, right?
Question 3: This is the right kit for a 6P, right?
RyanA
Rhode Island
A lot of apps use this in 60 ohm for 2x cr or rcr. I think 30 ohms may work as well. 60 ohms is probably better.
Works with and is similar to sf lotc. Function is like an L1 switch.
Yes mcC is a C-body (6p) kit.
Make sure to check the link on the sales page. A lot of good info.
adamlau
Los Angeles
1. I have beamshots posted somewhere on CPF comparing 15, 30 and 60 ohm versions w/ and w/o an FM34.
2. Yes it does.
3. Yes it is.
