I have had my DBS v2 now for 3 days and I really love this light. Now with that said, I would like to know if anyone else with a DBS v2 is or has experienced the problem I am having.
I have the 3SD pill and when I turn the light on high everything is working fine but when I switch to Med or Low, I start to get a lot of flickering and the squealing is very loud and it too changes as the light flickers. I originally thought it might be the switch so I installed the spare one that comes with the light. At first I thought thats what it was because it seems that the flickering stopped after the change. Nope... The light would not even turn back on a few hours later. I have to loosen the tail cap or head alittle and tighten it back up and then the light will come back on, but the flickering and the squealing is still there. I have cleaned, re-lubed all threads, tried 2 other brand new AW 18650 batteries (4.19 volts) with the same results.
So I ask, is there something else I can try to resolve this problem or do I have a defective pill. When I had my DBS v1 with the 3SD pill I had no problems at all and I never noticed the squeal that everyone else has until I received the V2.
I guess I will contact Alan to see what can be done.
Thanks
Thanks
