I just bought a new Brinkmann "Tuffmax" LED Clip Light at Walmart after church. It is a 2AAA side by side form that has a clip on the battery end to change cells. It also features a 90 degree rotating head and a high power LED I think a luxeon. It lists it as 45 lumens and uses an optic? (maybe it is a short reflector) so the beam is similar to my streamlight lux jr. The tint isn't perfect either whitish but shifts to yellow/green as the batteries drain down. The light is plastic and has an interesting foward clicky switch on a panel on the side where it looks more like a brinkmann label than a switch. It must be driven fairly hard as it does heat up and looks like it may have thermal protection as it dims as it gets hotter. Cost is $10.88 plux tax..
Pros....
nice clip better than cheaper lights using 3AAAs
90 degree rotating head and tail stands ok too
bright enough to be useful for most things
looks are good.... not cheap.
switch is weird but nice when you get used to if, forward clicky a plus
price is very good for what you get
small size 3.25" L x 1.5" W x 1" D
like has very useful spill even though the beam is weird
Cons....
seems to get hot and light output drops
weird beam pattern that can be ugly to some
tint isn't great but at the cost acceptable
battery latch may be a problem down the line, don't like it very well
head rotates 90 degrees upward from the side of the switch so you cannot rotate it down using it with your thumb on the switch but may be good for a clip on pocket light.
not sure about it but runtime may be short due to output and 2AAA
would love to see a 2AA version only for that reason.
I don't have a picture or runtime I will leave that to someone with a good camera and equipment but my guess is about 1- 1 1/2 hours to 50% on nimh 800 mah batteries. If nobody else posts it I will try to get a current reading off the batteries.
They also had another 1AA brinkmann LED light on the same peg I think at the same price too.... I didn't buy it though. The peg seems to have alternating lights on it but other stores may put the different lights on seperate pegs.
Pros....
Cons....
