Sorry to be Quite frank, but what could you possible run a ROP bulb with that would fit in a 2xAAA or even 2xAA Minimag? 2x 14500 would produce the 7.4 volts required by the hi bulb but that bulb needs over 3.4 ah! When I posted here about running a ROP low bulb on standard cr123 lithiums some people didn't think they could provide the 2.5 ah needed, while others thought that they could only provide the same as the rechargeable one which can only give 1 ah. So how are you going to pull 3 times that power out of batteries half as big as "2x AW 10440 lithium "AAA size" And we are not even talking about volt sag under such conditions. So unless some one here knows differently, I puzzled. Next in the
Auroralite hotwire mod Why isn't the Streamlight 2L bulb used instead of the TL-3. That bulb was built for 4.5 volts while the 2L bulb was built for 6 volts, You would still be overdriving the 2L bulb while having a much better overall bulb life. After all xenon bulbs don't seem to normally be happy being so drastically over driven? By the way were can you get glass lens for 2xAAA Minimags?
