Please do post your notes. Can you draw a runtime plot. Does not have to be fancy. It will be interesting to see initial start up, compared to rest of run. Will show heat effects on output and sort of show what kind of circuit Gene is using. I know it is running in sort of a buck fashion, but I think it is not straight buck regulation drive. Did you do any current tests at different points of run? Would show increasing current draw from battery as run progresses, or might show a drop in current for a different kind of circuit than straight buck.
Bill
I'm not too good at drawing graphs, and no current tests I'm afraid. But here are my notes. (All testing done between 4pm - Midnight, over the course of two days, using two fresh Surefire CR123 cells. Light was constantly monitored while on).
5:00 - 5:30 ~ Full brightness. Very hot to the touch.
5:45 - 6:15 ~ Same as before.
6:30 - 7:00 ~ Same as before.
8:00 - 8:30 ~ Output a bit less. Light is very cool to the touch.
8:40 - 9:10 ~ Same as before.
9:15 - 9:45 ~ Same as before.
10 - 11 ~ Same as before.
Next day
4:50 - 5:20 ~ No change from yesterday's latest results.
5:30 - 6:30 ~ Same as before.
7:00 - 8:00 ~ Light is even cooler to the touch. Not as bright as before.
8:30 - 9:00 ~ Same as before.
9:20 - 9:51 ~ Same as before.
10 - 10:14 ~ Light still going, but incredibly dim.
*Runtime testing stopped at this point since output is only useful for reading short shopping list written in memo pad, held up to the light.
Total runtime = 7 hrs. & 45 min.
