when i first got the L2D i test ran it to see how long it could last, i let it tailstand and after 13 minutes it overheated and dimmed down
So i know some have seen this as an issue some may not as they either have it on a bike with cool air flow or constantly in hand for more heatsinking BUT if you like to be able to tailstand it on a table in the middle of the room it will overheat after 10 minutes and go dim and kill the batteries....well i went to Home Depot and browsed a few items and found the best i could a copper pipe 3/4 inch it said "diameter" and 1-1/2 inch length ...the length is perfect as it is same exact length size as head but inner diameter was a hair to loose so i had to use aluminum foil to fill the gap which came out very good , now all i have to do is finalize the solution by epoxying the edges front and rear only ,dont wanna gum up entire inner tube head incase i wanna disable later..and of course paint it black
ran it for 1 hour and it got hot but it stayed bright and did not die , i shut it down after an hour which was plenty for me to know it works well enough...also it was done in a room at normal temp around 70 degrees with NO FAN or Air Conditioning to help
i was hoping to find same type pipe but a little more beef in thickness,this is kinda thin but it works
