Hi all
I started this as a new thread because I think that what I´m about to tell you is a little bit different from what I´ve read so far in all the reviews and impressions concerning the EX10 light. I´ve received mine about a week ago after a long wait because the Post here was on strike. Pitty because 4sevens was so kind in sending it per First Class International Post at no charge. But anyway, that means, my light is one from the first pre-order batch. It came with the known operational problems due to the thick layer of viscous lubricant on the piston. Knowing that, I cleaned up the piston, lubed it with a fluid silicon based lubricant and put it to work. It worked a little better but still with some erratic behavior. Then I looked at the contact ring and saw that it didn´t travel smoothly back and forth (this has been already discussed in another thread). So I disassembled the head and lubed the spring underneath it but even after that I noticed that the ring occasionally didn´t moved freely and got stuck in the middle of the travel in a tilted position. Put it again to work and it was a little better than the last time but still far from satisfactory. Then, last night when I was outside in my darkened backyard testing the light and trying to make some rough comparisons with my Novatac and HDS, it happened what shouldn´t never happen, that is the light when turned on wouldn´t stay on after releasing the switch. It started to act in a momentary mode although the head was tightly screwed. I opened it up, pressed the contact ring a few times closed it and it worked again. This problem happened again twice afterwards and I think this could be a serious issue in a real emergency use! It is important to note that I could not reproduce this defect again, which means, it happens randomly.
I´ll list down the issues that I still have with the light in decreasing order of importance:
1 - Goes to momentary mode as discussed above
2 - With the light on, I frequently fail to switch to max (two clicks and hold) or switch to min (two clicks). I succeed only after trying several times with different frequencies between clicks. It appears to me as if the tolerance for the variation of this frequency were very tight. A little faster or a little slower than the prescribed value and the MP won´t register the command. Just want to note that as an HDS and Novatac owner I´m very much used to this type of UI.
3 - Even with the lubrication described above, the piston is very stiff and the travel appears to be very short. Sometimes it seems to have no travel at all; it goes on and off apparently without any noticeable movement! Due to this stiffness, an operation which demands changing levels between extremes or ramping for a certain time duration can be very unconfortable; it makes your finger ache.
So that´s it. Needless to say I´m a little disapointed that such an otherwise excellent product has those characteristics (I don´t want to name them flaws).
What I would like to know from you guys is: Am I being to picky? Did I miss something or is there anything else to be done in order to correct these problems?
Thanks in advance for your advice.
Bob
Bob
