trucker1964
- Joined
- Jul 18, 2008
- Messages
- 23
Hi I wrote to Fenix and I will try and cut and paste what they said.
Thank you for replying. I have more questions.
Could the TK11 handle the voltage of two 18650 Batteries? If yes will you ever make a extension tube so the light can hold two 18650 batteries?
It seems like if the TK11 can handle two rcr123 batteries it should be able to handle the voltage of two 18650 batteries.
Thanks.
Hello John
Yes, the safe volt of the TK11 can reach two 18650 battery, but now, we don't make the extension tube, and I will forward your idea to our R&D department for their reference.
Any more question, feel free to contact.
Best regards!
:thumbsup:I want an extension tube. Anyone else with a TK11 feel the same way should write Fenix and ask for it, maybe they will make it.
I know it will make the light longer but you wouldn't have to use it if you didn't want to but it would be nice to have the option.
If I understand things correctly at that voltage we would get the good regulation that we are not getting with the single 18650. They told me previously that turbo mode is regulated with two cr123 only because you need a minimum of 3.9 volts to produce 225 lumens.
Maybe someone smart could figure out what the run time of two regulated 18650 would be. Might be a lot.
Maybe some other company could produce an extension tube. It would be nice to have the option, sorta like the way the Lumapower MVP is reconfigurable.
Thanks.
Hello John
Best regards!
