Spartanian II Review
ernsanada
I just received a Spartanian II pre-production sample from neoseikan.
The final production version should have better knurling.
The Type III Hard Anodize should be improved.
The sample sent to me had some spots in the Black Anodize. The Natural Color Anodize has some 'blotches".
The Spartanian II feels very "hefty". It reminded me a combination of different MR Bulk light's.
My version comes with a deep OP Reflector. Uses a Cree XRE Q5.
The switching or changes of light levels is done with the "knurled" part behind the lens Bezel Assembly. Turn right or left and hold the knurling for a second and the light stays on. If you want to momentary on just right for less than a second. To shut off the light turn the knuling to right and hold for about 2 seconds. The switching mechanism will return to neutral. Spring actuated.
The Spartanian II must be turned on to get to the other 13 levels. Turn the knurled bezel to the left to get to the lower levels of light. Turn right to get to the upper levels of light.
If you want the Spartanian II to "memorize' the setting set what level of light you want and twist the rear battery cover around 1/8 of a turn counter-clockwise until the light shuts off. Twist the rear battery cover clockwise and you have the light set to that light level. You can set either the left or right turning of the knurled bezel to set a desired level.
The only drawback is that say if you have the light set on the "right" to high on and the "left" to low off you have to shut off the light in "right" high to get to low which is set to "left". It may sound confusing but it is very easy to figure out.
I took the Spartanian II to work to use and found out the light accidently turned on in my front pocket while I was working. A good idea is to loosen the rear battery cover about 1/8 of a turn to keep the light locked off.
I really like the Spartanian II. The UI was very easy to figure out. The switching to get get to the different levels of light is unique to me because I am used the rear clikie's, rear twistie's and side button lights.
I was sent an email and told not to twist off the head it may destroy the driver.
Made of Alcoa 7075-T651 or Alcoa 6061-T6
HAIII, 50~60um. Gray or Green or Black.
CREE XR-E Q5 bin.
Foretech Driver Board for Spartanian2.
13 levels. (from 0.5mA to 700mA).
1*16340/RCR123A battery.
Fully Regulated.
Over-discharge and reverse protection.
SCHOTT B270 & Dual-coated Lens.
The Positives.
Can fit AW's Black RCR123 with no problems.
Very easy to use UI.
Deep OP Reflector gives some "throw" in the beam.
Bulit tough.
A good low light level.
Very easy to use one handed.
The Negatives.
No rear lanyard hole.
Has the "Cree Ring" on it's beam. I know it will bother the wall hunters but it does not bother me.
Hopefully the final version can offer a OP Reflector version. A lanyard hole maybe nice.
Price TBA.
Use a Cree XRE Q5. SMO Reflector. Final version to have a better focused throw reflector.
Rear of the Cree Q5 Module.
The final version will have a better gold coated tail spring.
When I actually saw the Spartanian II it reminded me of one of MR. Bulks lights.
Left to right, Spartanian II, MR Bulk's Chameleon, MR Bulk's Lion Cub
Size comparsions.
Left to right, Spartanian II, JETBeam Jet II, Nitecore PD, Fenix L1P
I also took lux readings of the lights above. These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using AW's Protected 14500 and AW's Protected RCR123's.
Spartanian II
Level 1 - 10 lux @ 1 meter
Level 2 - 40 lux @ 1 meter
Level 3 - 160 lux @ 1 meter
Level 4 - 690 lux @ 1 meter
Level 5 - 1010 lux @ 1 meter
Level 6 - 1300 lux @ 1 meter
Level 7 - 1840 lux @ 1 meter
Level 8 - 2380 lux @ 1 meter
Level 9 - 2900 lux @ 1 meter
Level 10 - 3370 lux @ 1 meter
Level 11 - 4240 lux @ 1 meter
Level 12 - 4920 lux @ 1 meter
Level 13 - 6260 lux @ 1 meter
Spartanian II RCR123 - 6260 lux @ 1 meter
Jet-II Q5 SMO RCR123 - 4070 lux @ 1 meter
NiteCore Smart PD D10 1AA 14500 - 2060 lux @ 1 meter
I did a run time with a fully charged AW Protected RCR123. The Spartanian II was set to high. Level 13 - 6260 lux @ 1 meter
Temperature averaged 97 degrees on Lens Bezel Assembly during the run time.
6260 lux @ 1 meter....2 minutes
6150 lux @ 1 meter....5 minutes
6130 lux @ 1 meter...10 minutes
6100 lux @ 1 meter...15 minutes
6090 lux @ 1 meter...20 minutes
6070 lux @ 1 meter...25 minutes
6070 lux @ 1 meter...30 minutes
6060 lux @ 1 meter...36:50 light shut off.
At about 36:20 minutes the light blinked off then on once about every 10 seconds until the light shut off
This is the run time set a level 9 - 2900 lux @ 1 meter with Aw Protected RCR123 (Black).
2840 lux @ 1 meter....00:15
2820 lux @ 1 meter....00:30
2800 lux @ 1 meter....01:00
2779 lux @ 1 meter....01:15
2780 lux @ 1 meter....01:30
2740 lux @ 1 meter....01:45, SS II started to go into low voltage mode.
2740 lux @ 1 meter....01:46, SS II Shut off.
This is the run time set at level 4 - 690 lux @ 1 meter with AW Protected RCR123 (Black).
680 lux @ 1 meter....00:10
670 lux @ 1 meter....1:30
660 lux @ 1 meter....4:20
650 lux @ 1 meter....7:20
640 lux @ 1 meter....8:30
630 lux @ 1 meter....8:40
630 lux @ 1 meter....8:48, SS II started to go into low voltage mode.
630 lux @ 1 meter....8:53, SS II Shut off.
Spartanian II ran 8 hours 53 minutes in level 4.
Spartanian II @ 90"
Jet-II Q5 SMO RCR123 @ 90"
NiteCore Smart PD D10 1AA 14500 @ 90'"
Left, Spartanian II. Right, Jet-II Q5 SMO RCR123 @ 90"
Left, Spartanian II. Right, Jet-II Q5 SMO RCR123 @ 90" Stepped down exposure
Left, Spartanian II. Right, NiteCore Smart PD D10 1AA 14500 @ 90'"
Left, Spartanian II. Right, NiteCore Smart PD D10 1AA 14500 @ 90'" Stepped down exposure
Spartanian II @ 32'
Jet-II Q5 SMO RCR123 @ 32'
NiteCore Smart PD D10 1AA 14500 @ 32'
neoseikan
Some additional specs:
1- "If you want to momentary on just right for less than a second. "-> Or left for less than 5 seconds.
2- When the light is OFF at the highest level, it can still be ON, at a lower level.
PhantomPhoton
NV
Looks like the smo reflector has some nice throw.
Thanks for the review, I've been wondering when this light was coming. Looks like it isn't too far out now.
neoseikan
Hi. PhantomPhoton
Yes, we almost spend a whole year on Spartanian2.
But the final version will appear very sooner than elder versions.
Kurapica
Thank you for your review. We are finalizing this product and have done a lot of bug-fix and feature enhancement in our lab and factory since we sent this batch of sample. With the final version, almost any aspect will be improved. I think the final version will be here soon.
orcinus
Croatia
Can't wait! Looks like a really nice light (if a bit oddly designed :poke::D).
Wonder what the price point will be...
kaichu dento
現在の世界
Love the UI and high output and hopefully the new reflector will smooth out the beam.
(Your backyard beamshots may have me sold on a Jet-II !)
Nice comparison chart for high beams; any chance of getting you to post a similar one of low beams? Particularly interested in knowing if the Spartanian can go as low as the D10.
Thanks for a great, and highly anticipated review!
ernsanada
Added run time.
See above Post #1
ernsanada
Added run time.
Spartanian II ran 01:46 in level 9.
See above post #1
orcinus
Croatia
2800-2900 lux for over three hours on a single RCR123? :faint:
I'd say that's pretty impressive! :D
ernsanada
Sorry,
I made in error in the numbers.
Spartanian II ran 01:46 in level 9 when the light shut off.
Above post corrected.
orcinus
Croatia
Don't do that, nearly got a heart attack... :D
Still, 1:45 is pretty nice too!
