RofisLight
Results 1 to 10 of 10
Thread: Does anybody make a luxeon headlight?
    Mar 2002
    South Dakota
    Default Does anybody make a luxeon headlight?
    I am looking for a nice bright led headlight. It would be nice if it was at least as bright as the PT aurora, but I don't want a multiple led light. I want a single 1 watt luxeon light. Does anyone make such a light? It would also be nice if it was regulated, and dimmable too. Thanks! [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Flashaholic* V8TOYTRUCK's Avatar
    Jul 2001
    San Gabriel Valley + Burbank
    Default Re: Does anybody make a luxeon headlight?
    I believe our very own Elecktrolumens makes a LS headlight.
    http://elektrolumens.com/LS_HEADLAMP/LS_Headlamp.html
    Jan 2001
    Mesa, AZ. USA
    It is not out yet, but check out the Action Light 3 from HDS. This has a 5 watt emitter and is uC controlled.
    www.hdssystems.com
    Peter
    Jul 2001
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=16037
    Maybe you can get a better price on CPF?
    The big problem with making a Luxeon headlamp is the power to weight ratio. You can either build a lightweight unit that is not very powerful or you can build a full powered device that is relatively heavy. If you make a light weight unit, it better be underpowered because driving a Luxeon at full power without full heatsinking is bad business. Either the LED is going to overheat and fail unpredictably or you are going to inadvertantly use your customer's noggins as heatsinks. While some businesses may think that an appropriate use for their customer's body parts, we at InReTech value our customers more!
    At InReTech we know that many of our customers are attractive, hardworking, intelligent, and have their tort lawyer's number on speeddial. Consequently, we make it a key design principle to never invite that call by causing smoking holes in customer's foreheads.
    What I am saying is this, you should either prepare to carry a professional grade, heavy duty housing for a Luxeon headlamp or underdrive the Luxeon substantially. The heavy duty model may be uncomfortable, expensive, and inconvenient, but it will not fail and it will not harm you. If you try running a Luxeon at anything near full power without proper heatsinking next to vital portions of your anatomy, you risk parts failure and pain.
    We would like to produce a headlamp using a high power LED solution, but we do not feel that we have the capacity to do so well right now. Of course, we may solve that problem soon...
    Flashaholic* Wits' End's Avatar
    Nov 2001
    Remote NEast Minnesota, next to Lake Superior
    Did you see this thread?
    Rayovac 3 in 1 headlamp mod
    Aug 2002
    PA
    I'm working on the tonyb microlux headlight right now! It will be small, bright, and dimmable and only use one small strap around your head. I debating if I should make it focuable. Here is a Preliminary Pic of step up electonics with dimmer control and emitter with heatsink.
    Nov 2001
    Houston, TX
    In addition to Electrolumens, have you seen THIS THREAD?
    Mar 2002
    South Dakota
    Thanks for all the info guys!
    Flashaholic* shankus's Avatar
    Feb 2003
    Mojave, CA
    What about an EverLED in a PR based headlamp?
