Hi all,
I went to switch my D10 on today, and found that it only switches on about 50% of the time. I can twist the head to the point where it's tight, and it won't go on, then I untwist it, and re-tighten it, and it goes on. Same thing with the tail switch - I can push it fully in (with the head loose or tight, doesn't seem to make much difference in whether it works or not), and it will only sometimes activate the light.
I've done a bit of testing to see if I can feel whether it's a contact problem or not. I untwisted the head to the 'momentary on' position, and tried to activate the tail switch by pushing it in. I can push it in to the point where I can feel what I presume is the battery touching the terminal at the head of the light, and most of the time it goes on (probably 70% of the time). However, if I push it slowly, I can get to that point where I feel the contact, but the light doesn't come on. When that happens, it doesn't matter how far I push the piston in and increase the pressure on the battery, it still won't come on (which doesn't sound like a contact problem to me, but what do I know). In constant-on mode (head tightened), the light does the same thing, although the problem isn't as frequent.
The same thing happens when I try to switch it on 'normally' (i.e. not slowly activating the switch). Interestingly, it seems to get better the more I use it in a short time period, which would suggest a contact issue... but then I leave it and pick it up two hours later, and it's back to square one.
What happens with these lights when the battery wears down? I understand they're digitally regulated (I think?) So do they just refuse to come on if the battery is too dead to supply the necessary output for a given level? Or do they still work, and maintain the maximum brightness possible for as long as possible, then drop like a rock to minimum? What happens when it gets to minimum, and starts running out (3 lumens)? Does it keep going until there's nothing left, like an unregulated light?
I don't think there's a battery problem, because I can still crank it up to full power, and it looks to me like full brightness (and keeps going).
Any ideas? Sorry for my long-winded post.
Edit: I just realized the first paragraph makes it sound like I don't understand the UI of this light. I'm pretty confident that I do
