Re: YOLight? LEDs from Yoldal
I've noticed the blue-ring effect as well, with them slightly underdriven as well as at full rated power. Brightness looks to be comparable to a S-rank Nichia (in the same mcd range, anyway), but beam quality's definitely not as good. I'm guessing that Yoldal's manufacturing process for these doesn't accurately control how even the phosphor-layer thickness is across the entire die and die cup, and thus you end up with thin spots around the die that let more blue get through. (Nichia, OTOH, spent a LOT of $ and time on this specific aspect of mfg. white LEDs, as their smooth beam shows.)
On the upside, these should be great for arrays as multiple LEDs all on-axis will blend the bright spots out and make the overall beam smoother. Not to mention the fact that you could build a large (24+ LEDs) array for about 60% of the cost of the Nichias.
But, for single LED applications, or arrays with only a few LEDs, one would be better off with S-rank Nichias.
I can see where the Yoldals would have their place in the LED building/modding community. They still have some work ahead of them to take on Nichia.
oO
