kelmo
Greetings!
I used it last night goofing off around the yard. The tint is white very. The beam is a nice wide cone of light with a big hotspot and very large spill. The pattern favors flood over throw. It is a mini L2. This minimizes the LED color washout effect.
The switching is cool. The setup instructions seem complicated but are very intuitive once you actually start programming your light. Twist the bezel to activate the 1st stage, continue to twist to activate the 2nd stage for constant on. I set mine to levels 3 (40 lumens?) and high. The high compares favorably with my L2 on high. The kilroy or tail button is truely a ***** to activate. I rock climb and I have to exert a considerable amount of effort to use the switch. As the plunger is depressed you 1st activate the low then high when fully engaged. When the light is in constant on "low" the kilroy can be used to jump into high. The virtual setting is cool. A fast full depression of the kilroy activates this. I set mine to strobe. Its there quickly if you need it. The virtual setting will not work if the light is in contant on mode.
Quirks - when you cycle the light fast, on-off-on-off the beam will flicker before it settles in. But when the light has been off for about a second the flicker is non-existent. There is a very faint whine from the regulation circuit. You have to put it to your ear to hear it. There is no inductor whine on high suggesting as others have stated that the high setting is running flatout out putting what the battery can support. When the light is strobing so is the whine and it sounds like a detonator on terminal count down.
Fit and Finish - The light is just down right beautiful. I have always been an Arc Fanboy so my impression is somewhat biased. The anodizing on my unit is flawless and matches perfectly. The clip is unpolished and like the kilroy takes a Herculean effort to move. The bezel guard is polished. The use of titanium for both is a very elegant touch. The Arc6 gives the impression it will float it is so light weight.
Overall I am very pleased with my purchase. The price point may not be for everyone but you can't deny this light's presentation carries on the original elegance of it's LS lineage.
Bravo Arc Flashlight!!!
