SunnyQueensland
Hi everyone...
I have a Novatac 85P on the way and would like to install a 'current' LED in it. I have owned the 120P but sold it as I wanted the ARC 6, I don't think that is going to happen. :candle:
My question is:
Is the 120P setup to run a certain level of current/voltage (I'm not sure which) from the factory, and if so will replacing the LED show any sign of improvement at all, or is the different levels of maximum output only related to the type of LED used in each model? :shrug:
While you are here, would you mind giving me a recommendation on which LED I should be using as the latest and overall brightest in this mod? :thinking:
Thanks in advance.
SQ
My question is:
Thanks in advance.
SQ
