I have modded two of these, first has a home made LED array of 9 paralleled white LEDs, 8 pointing radially, one pointing up. I used a "disembowelled PR- type bulb base, with a 10 ohm 1/4 w resistor in series with the array, inside the bulb base base. I SWAG'ed 180 mA current consumption, wanted 1.8V drop, so chose 10 ohms, The LEDs will draw more than 180 ma on fresh alkaline batteries, and pretty close to 180 mA on freshly charged NiCd or NiMH.
In addition, I put in two red LEDs in series, with a 100 ohm 1/4 watt resistor, inside the lantern's red transparent base.
The second, has an array of 12 yellow LEDs pointed radially,
two more pointing up, also with a 10 ohm 1/4 w resistor in series, and two blue LEDs in parallel, then in series with a 100 ohm 1/4 w resistor, inside the lantern's blue transparent base. The yellow LEDs are in 7 sets of two LEDs in series,
as they have about a 2.2 VDC operating voltage @20 ma.
7 sets of these should draw about 140 mA, I allowed a 1.4 V resistive drop, so 10 ohms was chosen. I figured this would work as a "bug light" and the yellow light is decent for outdoor lighting at night.
The colored LEDs in the bases are just for fun, they are not really needed.
Double check your lantern, some are wired positive to bulb tip, some are negative.
EverLEDs would need to have a notch filed into the outer rong in order to fit the R-O-V lanterns, as is done with a PR-type bulb.
/ed b in NH
