LED-holic
I went hiking over the weekend with my wife, and she complained her pink E01 that I gave her was not bright enough. She wanted something brighter like what I was using (my D10).
So I had her try out my D10 and my L1D Q5. She preferred the L1D Q5 because the rubber clicky is easier to use with her longer nails, and the UI was so simple she didn't have to practice to go to low / high / ramp up & down.
This led me to think about what would be the ideal attributes for a light targeted at women. I came up with a list:
1. Should be pink / red if possible
2. Should be as small as possible, to fit in their purse with all the other stuff they have to carry
3. UI should be dead simple, and easy to use with longer finger nails
4. No SOS, this will confuse them. Maybe strobe, it may come in handy to attract attention in a crowd or ward off possible attackers, but not required
5. Either a twisty OR a clicky, but not both. My wife was confused about twisting the L1D Q5 into turbo mode, so I suggested she just keep it on general mode and just click the tail to use the light
6. Should have a nice diffuser cap that will stay on securely. This diffuser will help protect the lens from all the other junk in the purse, and will be a nice way to use the light up close to apply make up, etc...
7. Should be able to run on alkaline well, and not require nimh or lithium to run well. I currently have Eneloop 1AA in the L1D, but I worry my wife may accidentally run the battery down too much and damage the battery. I don't want to put an alkaline in there, and I have no desire to buy lithiums for it either (this is why I stay away from CR123s). She does not require the extreme brightness so a L1D Q5 on medium should be more than adequate. If the light can run on an alkaline fine for an hour or more, then I would prefer to use cheap alkalines that she can run down to nothing and simply pop another alkaline in as needed.
These are what I thought would make the perfect light for most women.
What do you think?
What do you think?
