Hi guys,
I am new around but I have been reading this forum for over 2 years now. I just registered though.
In any case I noticed that there is not much info on the net about Konnoc batteries which are really cheap. I am a big fan of Sanyo and its LSD product line more recently, however I bought some sets of Konnoc AAA 700 mAh which so far seem to be good batteries. I need to make a few capacity tests on my LaCrosse BC700 and provide results here. One thing I noticed is that they seem to keep charge and have a low self discharge rate. I suspected this was true by measuring it's open circuit voltage, however now that I have my new LaCrosse I will do a few tests.
In order to provide results I would need you to tell me good standard tests, like for example charging rate, idle time, etc.
So far I intend to charge them at 0.5A (again these AAAs are rated at 700 mAh) and then discharge at 0.25 A
Then I would like to leave it sitting for some time and run a Test on the battery analizer.
Maybe you can suggest a few good idle times after batteries have been charged in order to maximize results reliability.
Looking forward to sharing results with you!
