I like the simple, small, and rugged Pelican lights, but the "Laser Spot" beam is too narrow to be useful to me. I wondered what this reflector would do with a broader source, so mounted a 5W HD V3U in a StealthLite reflector, put this inside a Mag 2D held in with a cut down reflector housing, and powered it with resistored 6AAs. I prefer broad beams with good spill, and wasn't disappointed.
Following are beamshots from this 5W StealthLite (5WS), a Trilight running off 4Cs (one of my favorites), and a BB400 all taken at 15 feet.
You can see the 5WS beam has a broad hot spot like the slightly purplish Trilight. The Trilight has more spill in the immediate vicinity of its hot spot. The BB400 is for reference.
The next set, taken from 15 feet with the light held at 3 feet shows the very broad and effective spill of the HD from the StealthLite reflector. (A slight modification would provide up to 15 more degrees.) The Trilight spill quickly falls away. The BB400 is again for reference.
For me personally, this is almost an ideal general purpose outdoor beam (other than the sharpness of the hot spot). It provides a fairly bright, wide spot while also providing quite reasonable flood. You could see well down a trail at night while also seeing obstacles a footstep away.
