Ostar aspheric has a little brother :)
cytoe
Made the ostar aspheric (https://www.candlepowerforums.com/threads/184326) a while ago. I found a single Cree Q5 threw the same distance as the ostar w/ a smaller beam. I decided to make one so I could use a single rcr123a:
Threaded so can be attached to a camera mount
my beer cap battery capsule
some comparison shots w/ the ostar version:
SafetyBob
Yukon, Oklahoma
I am eying a couple of my old computer heatsinks (mainly intel based), what heatsink did you use for both lights? Was it really hard to machine? I would think that that thin aluminum would be bouncing and flexing all over the place when you mill around it.....
Rotary table fun?
I love those lights though. I remember when you did the first one. Now I need to try and see what I can do too, since I have an aspheric lense sitting around not doing anything.
Beautiful, beautiful work!!!
Bob E.
cytoe
Thanks! The heat sinks are from work. I think they came from old PA-RISC servers. I milled them out using a mini lathe; the center is solid so no blade (fin?) flexing there. However, it would be near impossible to mill the outer blades and get clean results. Here's a bike light (posted on mtbr lights forum) I made using a similar heat sink:
Fried the Shark driver in the original heat sink light
Apparently, my sloppy soldering on the positive input shorted on the shark's c-heat sink. doh!
I never really liked how the back of the original turned out:
...so I thought why not take a saw to it
Fast forward many hours...
The 3 main pieces:
Inside the body. No more fried driver I hope
new back...
front...
side profile...
I redid the clamp part so it integrates better into body...
SafetyBob
Yukon, Oklahoma
Cytoe, just pulled apart the heatsink from an Intel Dual Core something or other....a couple of years old I believe.
With some grinding, sanding and milling I really like what I see. Don't think it will be as pretty as yours because of that amazing heatsink (they don't make them like that anymore), but with a small aspheric, this should be one really cool, custom flashlight....one CR123 or eneloop.....this decision stuff is for the birds, guess I will have to make one of each!!
I think I can do this!!
Bob E.
SafetyBob
Yukon, Oklahoma
I seriously hope that I can come close to what you have done.
Art? Beauty? Engineering? all three describes your little lights. Like I say, at least I have a goal to reach for....
Bob E.
