crofty
I watched the fenix maintenance video and wondered what lube they used so emailed them and this is what they said:
"ordinary silicon lubrication" ok fair enough, but Vaseline! I`ve read on CPF it shuoldn`t be used because it "could" degrage the o-ring, so that was a bit supprising but I guess if their recomending it then it should be fine.
If you look in their video they don`t lube the threads, just the o-ring. Find that a bit strange. The threads were lubed when it was new and when I cleaned them I tried it without lube and it definatly needs some.
ATM I`m using something called "Tri-Flow grease with teflon" it works but isn`t as free as it could be I think.
Despite the controversy (not sure what it`s all about and don`t really care) I`m thinking af giving nanolube a go. Maybe I`ll try some vaseline in the mean time.
The lube is just the ordinary silicon lubrication, or you also can choose Vaseline for use.
