Yes as the other similar but AA next generation Fenix lights are called "LD".Am I right to assume that "PD" has nothing to do with pistons?
the site says that the PD20 runs on 3.0v CR123s, does anyone here know if it can run on 3.6/3.7v RCR123s?? Primary CR123s are expensive where i live so i would have a few on hand but these would be more for emergency/back up use and i would be running mainly on 3.6/3.7v RCR123s
i see, guess that means i would lose the other modes. Hmmm, if that's the case, i may as well just go get a DX single mode light instead.
thanks for the recommendation man, but it's a little bit too complicated when all i need is high and low
It's essentially a single mode light. Not really complicated.
