Hi All
Looking for a spot of advice. Im looking to build a 3x P7 mod in a m&g head- the batteries will be contained in a seperate waterproof canister and will be connected via umbilical. As it is intended for underwater use, i will have the ocean as a pretty decent heatsink as well as the aluminum head.
Heres the question- how close together could you put the P7's? Ive looked at the specs, and it seems that 3 can fit on a H22A D size heatsink (was thinking id sand off the ridge and flip it round so the LEDs were on the flat side). i could add more aluminum for extra mass, and i would use paste between contact surfaces for more efficient heat transfer. In addition, since its a dive light, id have the Sea as a constantly moving, high heat capacity medium on the outside.
Any thoughts on if this is possible? would be looking to run it with 3 Li-ion at 2A. Intended driver is the 'poorman multilux' solution found on the site.
Cheers for any advice, much appreciated!
