Gatsby
I know that the Novatac is not capable of running of two CR123s (and the HDS can't run on 2x RCR123s for that matter) - but either should run OK with a 17670 - does anyone know if a 17670 will fit in the 2x123 tubes and if the old HDS tubes are compatible with Novatacs?
Just looking for a higher capacity option and trying to sort through the options such as they are (sure wish I could source an affordable 2xAA tube...).
